Holley retro drop in fuel pump
EddieSketti
Michigan
Thinking of buying the Holley intank fuel pump that fits your stock tank but it is for fuel injection. 58 psi. but was hoping all I need to do to run a carburetor is install a regulator to knock it down to 6-8 psi. pump has a intank return system. has anybody done this.
I had Tanks inc in Iowa I believe, they built my 66 Barracuda tank with the Bosch pump for my FI Tech injection. I used a 3/8” fuel line for the primary and a 5/16 stock line return; both from inline tube
Intank pumps are great BUT they take up a lot of fuel room. Plus the baffles . I bet I am down to 7gallons of fuel.
I would tend to agree that it would be a really big drop for that pump. Not sure if it can stand it or not.
dont they make a low pressure pump , they would be missing a lot of sales ,TBI systems work with 12 lbs systems/ and a 20 psi pump.
No, "you're" missing the point. I was joking in the post of mine that you quoted.
