Holley Sniper Stealth, No fuel pump prime, no handheld power.
slidey06
Member
New York
Just finished do some wiring on my 71 plymouth duster, all I did was eliminate the firewall connectors to clean up the engine bay. After this project, my handheld and fuel pump arent getting power. With my key in the run position, i get power to everything else, CDI, lights, the car cranks, Im getting 12 volts to the pink wire in the 7 pin connector to the sniper. I tested the fuel pump relay and the inline fuse, both are good. What else can I check? is the sniper just shot?
Thanks, Jeremy
