damn nice work sir!, im subscribed!
that's where hemitheus' idea about making a mold and running off some ABS ones is nice- it would make it easier to make some moretell us final cost maybe I'll try to talk you into building me one lol
...anyone have a big 3D printer they're not using right now lol?
somebody who's making a console said they bought 1/2" thick sheets at a sign supply shopI have never worked with ABS plastic. Do you buy it like lumber and then shape it with a router?:scratch:
You, Sir, are correct. I probably should have done a trial run in cardboard or something. The outer 4 teeth are about 1/2 inch shorter, but I should have made them an inch shorter because it's barely noticeable.How about making the middle 11 teeth an inch longer in height,since then it would come up to the bottom of your hood.Then you could slope down left and right to the 4 teeth on each side.One way or the other,It looks real cool!How about fabricating it first in cardboard,or foamboard,or balsawood,so it will be easier to work with.You will be able to figure out what to do with your diectionals with the easier working material.Good luck,your onto something.The new Chrysler corporation might be calling you,though.
