Honing Oil Options?
dibbons
La Paz, B.C.S., Mexico
I believe I have used brake fluid in the past for honing lifter bores and maybe cylinders. Since I believe brake fluid may soften the RustOleum red primer I used on the cylinder block, I am looking for some other lubricant. Thank you.
How much material are you removing?
In a pinch I’ve used solvent. That’s a bottom of the barrel choice but it’s a step up from dry honing.
I’ve used ATF, Marvels Mystery Oil and even WD-40 if it was just a slight touch up.
If you have to remove more than about .001 I’d let someone with a power hone do it.
You will generate a bunch of heat trying to take more than that by hand.
Just buy some honing oil, your parts store should have some. I don’t like using penetrating oils, fumes.
