Hood Clearance Survey
Killer6
PA
OK Slanters, I'm asking for Your help to document the amount of working space on all intake systems, stock to whatever Ya got. I will post the response form/order below. Please keep Your responses to info & data only. Thx! K6
A) Year/Model/K-frame(stk., mod., sandwich, spool..)/Tall or Short block.
B) Brand/Mfr of eng mounts.
C) Type/Brand of Intake Manny,(carb(s), EFI/stk-Aussiespeed-Gill welding etc.)
D) Overall height base to airhorn seat.
E) Carb(s)/TB Model, all adapters-spacers-NOS plates.
F) Type of filter(s), Ht. over airhorn base, Points of Minimum Clearance.
G) Minimum Hood Clearance Dim.
P.S. Please indicate if the head has been angle milled, or the intake raised on the head.
A) '64/Dart GT 'vert/stk. K, sandwich/225.
B) OE sandwich, DS.avg. 1.75",PS 1.80" .
C) OE iron 1bbl.
D) 4.1" W/.140" Base gasket.
E) Carter BBS
F) OE 8.75" OD assy./3.0" w/.125" airhorn gasket/front-Dr. frt. hoodskin.
G) 1.0"
A) '72 Duster w a/c, stk.-K sandwich, 225
B) OE Sandwich, Dr. 1.25", Pass. 1.625"
C) OE 1bbl. Iron.
D) 4.25" w/.130" base gasket.
E) Holley 1920
F) OE 11" OD, 11.75" OD lid./2.375" w/.125" Airhorn gasket/ frt. edge near brace.
G) 1.625"
* stud & wing nut 3/16" proud of lid*
Oh GAWD, if I must.
1964 Valiant 2 door seedan. 225.
Stock biscuit.
Offenhauser foe barrah. Quick Fuel 450 VS carburetor. 1.5" carburetor adapter.
Base of WHAT? Be specific.
See answer in "C"
F) Type of filter(s), Ht. over airhorn base, Points of Minimum Clearance. Spectre 14 x 2" element.
About 1.25" after cutting piece of inner brace.
