carcrazyguy
How much play should there be in A-body hood hinges when there is no hood attached? I stopped in to check on my 70 Duster at the body shop today. If you hold the main portion of the hinge, the upper hinge had quite a bit of play side to side (while holding the lower half of the hinge stationary). Is that normal?
