Hood hinge spring.
Buford19
Kitimat b.c.
Can a person remove the coil hood spring on a A body mopar? Is so how do you remove it? Currently I have it at this stage.
The slot appears to be peened, so it may require some prying to get it out.
slot is peened, or should be.
grind it out.
Thats what I did... unwound the spring 1/2 turn and peened it back in.
grind it out.
Yes this one is peened, was not sure if I should remove them. The reason I am removing the spring is because my hood is very hard to start the closing process. Thinking I should open the springs ,and lightly sand in between them. Hope this will help the springs smoothing out.
same reason I did what I did.
couldnt keep the hinges from splaying out every time.
give it a shot...tighten up the slop at every pivot/hinge point too if you can.
