:rr: my dusters hood when shut is three inches higher in back other side not as bad. ive noticed this on other cars as well .whats the cure i cant seem to find new ones .thanks
I am not an expert but I have a suggestion. Measure the angle on the good side and compare it to the bad side. If there is a difference use a b.f.h. (big f'ing hammer) and "adjust" to the same angle. If there isn't maybe there is some mounting adjustment you can perform. Possibly move it down a bit.
