JGC403
I have a sheet of aluminum that I would like to make a Max Wedge scoop with it. I have the scoop designed on paper. But I am unsure of how to design the mounts to mount it to the hood. Thanks for any input.
put 90 degree breaks in scoop where it will meet the hood, glue and/or use couter sunk pop rivits. The dond it out.
weld in female threaded nuts on the inside, then bolt it under from bottom. Then evercoat/ fiberglass. Anything else will crack. Been there.
That is an AWFUL LOT of work ... I would suggest just spending the 80-100 bux and buying one.
HOW ABOUT cutting-one-up and 'glassing it together for the Jeep?
AGAIN .... banging-one-out in alum/steel is a BIG job ...and requires REAL special tools.
