73 Duster 360
I know there are about of threads on here regarding fuel gauges and sending unit and all the problems that can arise with OEM sending units.
Here is my potentially dumb question that I've been unable to find an answer too...
If I replace both my fuel gauge AND my sending unit with OEM replacements will the linear ohm issue still be a problem or will an OEM gauge properly read the signal from an OEM sending unit?
I ask because a lot of the threads on here seem to be from folks trying to keep the original gauge and just replace the sending unit. I happen to already have a brand new in the box OEM gauge that looks original and a stock gauge that suddenly reads empty all the time. Since accurate sending units are so difficult to find I'm curious if my potential solution of replacing both would work.
Any info would be appreciated.
