replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,193
- Reaction score
- 8,436
Its application dependent, not a set in stone figureQuestion about compression, I read that an additional 1 point raise was worth 3-4 percent HP ?????
That's what they say here's a 8.5:1 650 hp vs 10:1 700 hp a 7.6% peak hp difference NA of two fairly close engines but at lower rpms the difference was smaller.Question about compression, I read that an additional 1 point raise was worth 3-4 percent HP ?????
654846648948595884212086559258853557890532689521808665330740135073680532075372076108636907512469065325700997645432223446668907664313417889076433244570975542226964948i06426075316890613749 ⅜ Horsepower.Anyone want to give me a horsepower estimate?
Agree. And Wallace's numbers will be right. But I'll bet the o.p. won't be happy. Wallace numbers are for cars built and tuned for the strip. Street cars typically show poor numbers.Make a pass at the track and see what Wallace says.......
nhra hp factor for 340s based on mph run in the 1/4 mile for stock class racing are 295 to 325 hpStock hi compression 340's were rated at 275 hp and later lo compression 340's were 240 hp.
just compare yours to stock numbers. If you want another 40 remove the air cleaner, water
pump, alternator, and exhaust like they do on the dyno to get a max crankshaft total.
There no reason people shouldn't be able to estimate to a reasonable degree, based off 56 years of past 340 builds, other than possibly low ish cr he has a decent combo, all cr does is raise or lower the entire powerband a few percent.There I fixed it for you.
"HORSEPOWER GUESSTIMATE"
The drag strip doesnt lieSorry guys...i only know of 2 stock 340 builds.
One dynoed 276 and the other was 286 hp. The Dulchich stock rebuild was around 280 i believe?
The 71 engines with the 800 thermoquad will gain another 15 hp and could eclipse 300 hp above 5000 rpm.
...and i think the earliest 340's only had a 565 cfm carb, but that is something i read.
LolI stand corrected, disregard my posts guys.
I don't know what a high cr 340 makes hp wise, I don't think it overly matters, but net rating is fairly reliable number, most engines seem to make at least 30 hp more hp in dyno trim over net rating so that would be around 275 hp gross for the low cr one, so I highly doubt the high cr 340 don't make more than the low cr, 300 hp sounds about right too me.Lol
People get but hurt in a hurry with the truth. I do believe an optimized purely stock engine would probably make around 300 HP. Stock.
Not much faith in the power making ability of the Small Block Mopar
Well if a 340 can't make 300 hp with a decent cam, headers and airgap, then the sbm is a pretty shitty engine then.What do you expect out of a few minor upgrades. This isn’t a Hot Rod ragazine or we would be guessing 500-550 to the tire. Lol
