You do a full-field test. If it blows the headlights out, she's a size large.
Kidding! of course
IIRC there are about a half dozen different sizes /types of passenger car units, up to the mid/late 80s ; A) early, non-isolated field roundbacks B) late, isolated field roundbacks, and C) squarebacks .The square/round refers to the diode heat exhaust openings.
Roundbacks
The early ones were small 35/45amp or so jobs. The later ones mighta pushed 60amps. The above mentioned thin stators refers to the exposed portion of the field coil cage. When you take them apart you find that the coil is actually bigger than the earlier lo-pos . The lo-pos are in the neighborhood of 1/2 inch to 5/8 worth of exposed laminations, while the hi-pos are less than half that. I've had lots of those apart.The small ones usually have only a single-groove pulley.
Squarebacks,
I can't recall much about these, cuz I haven't had much to do with them other than RnRs. They usually have two-groove pulleys.
These are heavy duty.I don't recall their ratings; maybe 75 to 100
This is what I recall
Oh and the chassis wiring for the squarebacks is much more robust.
