deanster Well-Known Member Joined Jun 21, 2008 Messages 171 Reaction score 0 Location western nc Jul 11, 2009 #1 Hi, I,m trying to remove the ac clutch and pulley but I,m not sure of the best way. Are any special tools required? Thanks...Dean
C Charrlie_S Well-Known Member Joined Oct 17, 2005 Messages 4,676 Reaction score 2,786 Location Silver Springs, FL Jul 12, 2009 #2 What compressor do you have? If it is the old stock Mopar cast iron 2 cylinder, just remove the bolt in the center of the clutck/crank. Then thread a larger bolt (don't remember the size) into the clutch, and "jack" the clutch off. Edit: jack bolt is 5/8-11
deanster Well-Known Member Joined Jun 21, 2008 Messages 171 Reaction score 0 Location western nc Jul 12, 2009 #3 Thanks Charrlie, I did that and it popped right off. Now if other things would go that easy!...Dean
