Nice work Matt!
Dang that's good work I m gonna keep you in mind. Mine isnt broke but I may have you do mine just to make sure it doenst break. That looks so good.$2.50 per pin plus return shipping.
Can I use this solder?this is exactly the way i done my board 8 years ago , no problems since . to the op get a butane pencil torch and clean everything super clean you will be hard pressed to get the heat with the iron . also use t.v. radio flux core solder . this is what worked for me and is very easy to do .
I will try to get Mike to repair it. Thank you.Yes. What were you using the first time? 95/5 copper pipe solder? (Not well designed for electrical if so, you'd need flux and lots of practice, as the size is just too much to manage).
BUT, as others have said, the strength comes the mechanical staking operation. Attaching w just solder, and it will break again after a few potholes. I'd send it to Mike.
FOLLOW UP:
I sent it to MoparMike1974 and he did an insanely great job. View attachment 1715495865 View attachment 1715495866 View attachment 1715495867 View attachment 1715495868
