Kevin Jonker
I hopefully will be getting some E.T. street radials soon and don't have a linelock yet. How do you get a burnout done safely without the line lock? What gear to start in with a 4speed? Thanks for the help. Kevin
FASTBACK340 said:I'd suggest backing off the rear drum brake adjustment a bit so the fronts grab harder and stand on the brakes after you dump the clutch. Use 2nd. gear. This will give you more wheel speed and tax the engine less by keeping the revs out of the stratosphere...
jamesmcclain340 said:an old racer trick i've heard about was adjust the back brakes with the E-brake set. when you do the burnout only the fronts will grab. pull up to the line and set the E-brake and at the end you have all four brakes to stop. who needs a E-brake on a race car anyway. hope this helps and best of all it's free!
littleman66 said:put a tack in the rear line of the master cylinder...
not a good idea to do, but its kinda cool to know
