My Car was in 600 pieces when I bought it. The PO took the hood off this car and used it on a drag car, so mine didn't have a hood when I got it.
The passenger side hood spring was in place but the hinge was off the pin on the end of the firewall. I put the hinge on the pin and tried to pull the hinge down by hand and couldn't move it. I assume with 4 feet more leverage and the weight of the hood it will function as it should, but I couldn't budge it.
On the driver side the hinge was dangling and the spring was in the trunk in a cardboard box.
How do you properly put tension on the spring and install it without accidentally amputating any fingers?=P~
