AlV
Crabs in a barrel
Hello FABO, I'm in the middle of my first suspension rebuild and learned a ton. I've read through many of the forum posts to learn the pros and cons of the various kits and materials. I ended up going with the PST Poly super front end kit BUT i used the rubber LCA bushing. Overall things have been progressing well and I'm in assembly phase.
My question is in regards to the movement of the LCA once the new strut bushings are installed. I have the back strut rod nut tightened to 100 Foot lbs and the front nut adjusted to 40 foot lbs as described in the service manual. The LCA pivot pin is right up aganst the K frame as it should be and I'm not experiencing that issue that others had where the arm is pushed away by the strut rod.
I'm going to do my best to ask this question because I have no reference to discern the answer myself:
What should I expect the articulation of the LCA to feel like? Loose or Firm? Should the arm be relaxed enough to just drop to the bottom under it's own weight? ( I don't have the brake assembly on yet)
I mean to say that when the K frame is raised the control arm stays level and does not drop as it did when the old bushings were still installed. If I hold the K and push down on the arm with effort it will rotate down but is very firm and when I ease off it moves back up to it's original position.
http://i953.photobucket.com/albums/...0-34ae-4cfa-8fe7-8c409b20dcac_zps385f1e44.jpg
http://i953.photobucket.com/albums/...A-E8B9-4C8F-8924-8D9C31F92B86_zpsw6vvflqk.jpg
http://i953.photobucket.com/albums/...E-2003-49CD-A3F7-D6AD67BFC904_zps5uyoakoa.jpg
http://i953.photobucket.com/albums/...2-F96C-4AB8-9775-7E9C5F9E541C_zpstq2q3epa.jpg
http://i953.photobucket.com/albums/...5-879A-4B84-A9B5-A0DFABEEA556_zpsqfveedoh.jpg
http://i953.photobucket.com/albums/...3-FB4B-4B65-97B7-0C69238CE238_zpsnoqdn3vq.jpg
Thanks in advance for your help.
-AlV
-AlV
