35% power increase for $150.00??? I got some land in Florida for sale and a fuel heater too...
Let me guess, you'll start a "gofundme" for developmental costs next.
Well like I said, it is only because the fuel pump shot that is being vaporized that I'm getting the 35%. The huge increase is only when the pump shot of a Holley DP is being vaporized completely, or close to it. You have to admit, that is a LOT of fuel being dumped in there. The increase at top end is only 8hp, but it never goes below an 8hp increase all the way from 3200-4500 RPM. But to a drag racer, or someone wanting to "take off fast" the low end is where you need the Torque and where this thing increases it.
Man tried to fly for hundreds if not thousands of years before the Wright Bros figured it out. Well. I may have, and I believe I did, figure out how to vaporize fuel inexpensively, without restriction. Bigger miracles happen all around us with Technology all the time. We used to also be lucky to get 12mpg in a V8, now cars get 25, or even more with comparable HP/Torque using a 6 cyl.
But basically that is why they call them breakthroughs. I broke through the "restriction creation barrier" when it comes to vaporizing large amounts of fuel very quickly.
I can't do a "gofundme" page, nor a "kickstarter" page because they want you to spill the beans in the page so people know your not pulling their leg. Seeing how some of you think this is completely impossible encourages me, but also lets me know how difficult it may be to convince someone without letting them try my proto on their engine on their test equipment. Well, all I can say is you "were" right, it "was" impossible but not any longer.
And the post that said I can't tell you how I do it is right. This device will work with FI, even Port FI, but it will be more expensive to install it. However, the increase will not be 35% because FI does vaporize fuel more completely to begin with. But for someone like Holley who is still selling carbs, this is a great product for them, and I could stand to make some decent money on it.
Thanks for replying, even though your doubt is obvious. I understand it "IS" hard to believe. I couldn't believe my eyes when I saw the dyno data print out for the first time either. I am going for a second set of before and after tests, to verify it wasn't a mis-calculation.
Thanks,
Bob
