abodyjoe
what axles you guys that are having an issue with the thrust button running?
i would stick with original tapered roller bearings or install them if you have the green ball bearings.
I don't know why anybody would install green bearings?
IIRC (and I can check tonight), they were Moser large bolt A-body axles, green bearings, 741 case with sure-grip.
Because they come with the Dr Diff kits....
Stock axles, in my case.what axles you guys that are having an issue with the thrust button running?
But there are millions of cars from all the manufacturers that came with that type of axle bearing. Mopar switched to them in, I think 1970. You very rarely see failures.if they are already installed i might use them but really they are throw away money makers for the auto companies and do fail. Check any dealer scrap bin and you will find a quite a few sometimes.If i needed them i would install o.e. tapered rollers though.
Yeah but how many millions did not fail. Ever?oh boy...i have changed 3 on my own newer vehicles.
Go to any dealer and check his scrap bin and you will find many replaced weekly.
If you say so. I'm not the only one that has had this problem. What's wrong with giving this guy a heads up? It is not hard to remove the button. Why not remove it? Why not, if it might cause a problem? I don't get this board sometimes...housing stock too? something wrong there..
i don't know.. my car has the same green bearing in it since the mid 90's. car was used as a daily driver for years then beat the hell out of on the street and drag strip, then it was set up for corners and driven a ton more like that.. green bearings still going strong.
My guess is that production tolerances just stacked up in the wrong direction. Housing flange-to-flange width is most likely a little short. Nobody here can deny that a lot of crap came off of the assembly lines back in the day. I have no good/precise way to measure that width, and no simple way to fix it if it is actually wrong. The quick fix was to remove the button, which worked.i'm trying to see where the problem was for your car..
yea check i'm curious... like i said i've never had a problem with the moser axles...
Refresh My memory real quick, what is the diff in length between R & L 8.75 axle shafts?UPDATE - they are Moser A-body axles with large bolt pattern (I dug out the receipt from when I purchased them 10 years ago). When I went to install them they wouldn't go in the last 1/4" or so, wound up pulling the center section to take out the spacer buttons.
0Refresh My memory real quick, what is the diff in length between R & L 8.75 axle shafts?
Oh, on the ones with the tapered bearings (adjustable). I'm not 100% sure on those.Couldn't recall if the adj. side was a tad different or not, not. Also can't remember if the thrust button lengths are diff between the clutch & cone style Sure Grips.
