Slappy
nice work!
What in the hell kind of motor is that? Looks awesome!
Made in USA beyotches......
Beautiful engine and boat ... that being said and not trying to be a douche but I believe that is a Meteor which was not supercharged and for British tank use
sweeeeeet boat
krazykuda's wood engine stand could almost be used with a forklift too, could load it on a pickup truck in 5 seconds that way
I'm looking to make a cheap/ easy engine dolly to transport my rebuilt engine to the machinist for a dyno run. Your design would be very easy to make. I was wondering of there are any concerns with resting the completed engine on the oil pan rails. Will it cause damage to the oil pan or affect the pan gasket seal?
It won't hurt a thing. The outer edges of the oil pan will kind of dig into the tops of the 2 x 10's, and the oil pan bolts bear most of the weight. I think I remember reading in your resto thread that you are waiting until after dyno day to paint your motor. So that will alleviate worries about skinning the paint on the sides of the oil pan. The motor will sit on the dolly, and never move while it's in the back of the truck. You could add some eye bolts thru the lower few inches of the 2 x 10's and use criss crossed ratchet straps across the motor if it makes you feel better. I do that myself.....but I do have a tendency to swap flies with a bazooka!![]()
Ill have to post up a pic of my afternoon Dolly project. I made mine so it could bolt up a tranny too, 6 casters and the ability to bolt it up and remove the pan. I plan on using 2" swivel casters @ 150lbs for a 900 lb load rating. Well see if it holds up. Mine HAS to bolt to motor mounts as that is what ties the side supports in. I got a glass smooth concrete slab floor, $24 in casters and $14 in metal.
Worked on my engine cradle today using krazykuda's design. All went as planned and seems to be working accordingly. This post was very timely for me.
If I may make one suggestion to this, do not use drywall screws. They are the weakest of the weak fasteners. While the plans do not have any place where shear strength is needed; a good decking screw will not rust, is a stronger fastener and not that much more expensive to start with. We are talking pennies here, spend a couple more for decent screws.
C
C
I just picked up the material to build mine to bring home from paint shop. If it was given, I missed the distance between the tall supports that the block base sits on. Anyone? Nice boat project BTW, I cant imagine the complexity of that deal!
TIA---DR:coffee2:
