How is this trim attached? 68 Dart GT
FlamesAreWicked
Active Member
Louisiana
I know the lower trim on this car is attached with clips but I’m not familiar with this mid level side trim.. is it attached via retainers, clips, or something similar? If it’s attached via emblem tape.. I’d rather take it off
It’s the thin side trim that starts by the side marker. It doesn’t go all the way to the rear side marker but probably 75-80% of the distance between side markers.
Thanks for the tip. I also thought it looked not factory issue… as you can see, it almost runs along the whole length. Since that is the case.. it’s coming off
Looks like whoever did it really did a good job! Would look OK without the factory GT trim...
