> I really like the deep skirt design of the oem. lifter. I suspect it will make a pretty decent solid, by gutting the hydraulics and replacing with a precision length tubing spacer.Put the oem. push rod seat back in, this time with a "circlip" and good to go. I haven't run this combo "yet" and i don't know the lifter, max travel possible. Good Luck, ateam.8)well i got a deal on a cam its a crower no.31407 will have .663 lift with 258/262 dur at .050 my heads a eddys hensley ported i am just new to running a mopar have run a bbc roller for yrs. just trying to learn and want to run a 10.50 indax class.car runs 11.80 on motor and went 10.99 with a 100shot. need to lower the n/a motor numbers. this was with a 557mp cam
so would you guys run this with 1.5 rockers or 1.6? I have the 1.6 but will change if need be.
I wouldnt bother with 1.6 rockers. Very little gain for the effort and money.
Thanks for the help. will be running this roller and the 1.6 rockers. was told a guy with a duster similar combo with 4.11 gear instead of my 4.30's ran 10.63's so i should be able to get this to my 10.50 goal. only thing i am up in the air about is brand of lifters. can get a set of compcams endura-x for $375 or the imm's for $550 or crowers for $620 + $100 if i want the hippo's.
