That doesn't make sense. Either you have the incorrect resistor or the coil is a dead short.
Voltage varies, on a factory coil / resistor, somewhere around 6 -8 with engine stopped and points closed (or Mopar ECU) and running somewhere between 10-12 with system running 14V.
