racerkilla
me and my dad run a average repair shop and work on anything.. mainly all late model cars, tires brakes, engines motors, brake lines etc etc
well were redoing a 70 charger for a customer
so far
got original 318 running so it can be moved had to take gas tank out and clean it and clean carb etc..
welded in both front t cap (the cap style)
new 1/2 back frame rails from above the axle to the back bumper, replaced the metal bracket/plate that holds bumper and gas tank straps,
replaced the trunk floor and extensions... (who ever tried to fix the trunk had so many zip screws and tar and just a mess)
subframe connectors
and other stuff here and there
what do you guys think labor should be for doing all that, plus the welding wire and argon.... ill tell you how much he thinks he should pay.. he thinks 500. our shop rate is 45 an hour. so think we only had 10 hours plus some on this car... For you that have done this.. its takes forever to fix someones mess and to get new metal in nicely.
he wants front floors put in it, 4 speed hump, the pedals put in, the white interior changed to black the 318 pulled out and a 440 with 871 is going in with a hemi 4 speed, torsion bars, disk brakes, 8 3/4 on super stock springs, torque boxes.....
what do you guys think... i think im gonna tell him to go else where... i know its a mopar but if i'm gonna lose on it i rather keep working on my own cuda.
i'm getting a 18x21 car port so i can tear down my 73 cuda apart and be out of the weather when i'm using shop for normal work.... hes like oh nice when u get your car port my charger will be out of the weather... yea right i'm gonna buy a car port for my car to sit outside......yea right
so far
subframe connectors
