How much improvement will I see?
25 initial, 35 total
That's a lot of initial for that size cam. In all honesty I would look at running a 600/650 Holley with your combination here's why:
To give you an example I ran mid 12's at 107 with a similar weight and camshaft but with less carb, less intake, less head and less gear. I had tried a 750 and 800 but it ran quickest with a 600.
Borrow one off of a friend and see how it goes.
Once you get the new converter in, disconnect the secondaries on the carb and tune the primary bog out from a dead stop hitting it to the floor. Then, load it to about 1500, and smack it. Then 2500, smack it. If it isn't bogging in those conditions, next step.
Connect the secondaries and do the same thing. Trying to do both ends at once is a pain. Make it easier.
You also need to find out what your car likes for launching. Some cars like to be loaded hard where they almost push through the brakes, other like to hit the converter like a ton of brick from idle.
This test engine has a bit more compression and larger solid cam in it. Just as a reference to the intake manifold comments and converter choice (hopefully it's the highest they can stall it). The cam in your engine may get you to about 5800 making power.
An Air Gap is going to pull through the range faster than the Torker 2. The Torker in that test had some plenum work and port matched. TQ/HP crossover doesn't happen until 5000 rpm.
And if you do want/need to load the converter up a bit prior to the hit, you have to make sure the remaining pump shot (since the throttle is already a bit open) is sufficient to cover the throttle stab. I've found using hole #2 on the pump cams is helpful for this as there is more remaining pump stroke when you do that. You can look at the Holley charts and compare the remaining stroke from various part open throttle positions.
Since I stage mine at 2000 rpm, I had to set the avatar up for that.
