how much initial timing mild 360 magnum
Apparently that dist I posted isn't even a real mag. It's just got a coil in there along with an ignition. $300 is no deal for a fake mag
How do you adjust how much mechanical the distributor puts out? I just did my first swap. Mopar performace distributor. msd box. set initial at 10* 12* and even 16* seems to run way better at 16* no pinging or anything. Just pulls way harder. I didn't know you could set the total or all in. Not even sure where mine is.
