MOPARCODY
thinking about running a small shot on my 360 crate motor. motor only has about 10k on it. how much of a shot would be safe. i plan on using a window switch
lol!!!run it until it blows up, then back off a bit....
That sounds like it could lead to some unhappy results.so i should start with a 200 shot and add about 10 degrees of timing?
You ever hear that Ricky Maze skit? Kaboom, kaboom, Edited for sakes....
It should take a 100 shot if the tune up is right for a long time,
thanks for all the replies. i just picked up a pieced together cheater kit thats adjustable from 100-300, i have a 2 gallon rci fuel cell separate from my tank and another holley blue pump. i still need to get a wot switch bottle brackets blow down tube and a purge kit.
anyone know the rules for running nitrous at the track?
No set in stone rules, but there should be 2 in my book.
No warming bottle with torch.
No loose bottle in car.
Well damn that takes all the fun out of getting hit upside the head with a red hot nitrous bottle.
Have you ever seen what happens with a bottle explodes or...........Ain't pretty.
150 would be safe.
We ran 200 on a 1990 vette, 150 stage 1, 50 stage 2.
That thing had hundreds of passes on it.
....and likely had forged pistons.
No but it doesn't take a rocket scientist to figure it out. Acetylene, oxygen and nitrous. Do the math. lol
No necessarily in a 1990 corvette if the engine was factory.
pistons, crank and rods were stock but I don't know if it had forged from the factory..
