roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,890
- Reaction score
- 3,709
What else is there for a nitrous tune besides timing and cooler plugs? How much timing do you recomend puling out?
Its just a baseline for a safe timing pull, then you tune from there. Most kits are jetted on the richer side & thats what is recommended as a safe starting point, nothing written in stone. Not fare to make a rash statement, you are basically calling most in the nitrous business clueless or dumb because thats what they "still" recommend to this day, & i'm defending some of the best in the business.
No set in stone rules, but there should be 2 in my book.
No warming bottle with torch.
No loose bottle in car.
I'm running a 125 shot (55n/47f) on mine right now and have put about a dozen passes or so on it. I'm at 8 degrees of timing pulled to wind up at 26 total. I thought I was being very safe pulling that much and was surpirsed to see it was about right after reading the plugs.
UOP,how is the response off the bottle,pulled back that much?....
.I'm putting a 4 stage digger on my motor and the gentleman that is helping me when I asked him said the following
For every 50 increase in nos pull out 2 degrees
Don't activate under 3500 rpm
If running multi stage then for the first stage of nos for every 50 hp of nos in the first stage pull out 50 then every 50 after the first stage pull 1
Anything over 100 shot run race gas for at least the fuel side of the nos system
Use a bottle warmer not a torch pricey yes but safe
No more then 1500 psi in a single bottle
Use as small of a bottle as possible to have maximum punch( don't know why that's wat he said)
That's wat he told me when we were discussing my motor I have never had nitrous before and now I'll have 4 stages lol
Posted via Topify using iPhone/iPad
Speaking of the Keg intake and nitrous, I’ve heard of the plenum pans blowing off with nitrous backfires before...I've used a Compu Car hat system & built my own system using a Vortex Billet throttle body spacer The hat on a 01' R/T Dak & the Bob built on a 98' SS/T
The Magnum itself will hold 150 when metered correctly with stock hard parts Finding that happy go lucky medium with a factory EFI system takes patience
Most have an over rich condition starting out due to air temp change in the keg when the spray is hit
