RAMM
This is a thread that may not sit well with some but it is an excellent example of a poorly chosen combo and good money thrown after bad. I had a customer bring in .04" over 318 (325) for dyno testing recently. Very nice looking engine. The customer had a huge say in the parts chosen and purchased many of them himself off the good 'ole internet. Customer also must have gleaned all of his info from the internet as well.
The engine here ran flawlessly, no smoke, no leaks, no noises, revved clean etc..
The combo: '78 318 block .040" cast flat top piston (more than likely at least .030" or more in the hole), stock turned crank, Scat I-beam rods, pressed pins, Mopar cam flat tappet hydraulic .430" .450" 110, Edelbrock LA heads, Comp Magnum steel shaft rockers--LOL, Endurashine Eddy RPM Air-Gap, QFT 600 Slayer.
Peak power of 320 hp @ 5600 340 tq @ 4000 and this was really searching for optimum timing/jetting. The HV oil pump @ 104 psi probably didn't help, and the very nice custom aluminum oil pan probably put a $500.00 dent in the budget as well.
I had some time alone with it and was able to check lifter pre-load and compression test a few holes which pumped 135-145 psi.
This is a perfect example of throwing a lot of money with very little knowledge at an engine build. J.Rob
