Richie
Is and 8 1/4 rearend strong enough for a 340 with about 320 hp. Not for racing but for poopin around the street with.
I'm glad I swapped up to an 8 3/4 on my build. I had an 8 1/4 out of an F body in mine and when I pulled the cover to take the c clips out so I could pull the axles for the brake setup I was amazed at how small everything looked. The axles were a joke and probably not even an inch thick at the smallest section. The ring gear looked tiny as well, but I don't know if there was any difference in the setups from the different years or body styles. I pulled one out of a 69 Charger that I didn't think looked as small, but for driving around the street I wouldn't worry about it. I intend to race mine and do some big engine upgrades in the future, so I'm planning ahead. There is definitely more of a difference than just a 1/2 inch of ring gear diameter between the two though, lol.
Sounds like you had a 7-1/4 not a 8-1/4.
The later 7.25's had 3" axle tubes that necked down to 2.5" where they went into the housing.
Well, just for fun I grabbed some pictures. The axle is a tapered one, which might account for why it looks so pathetic, but it measures out a pretty much one inch at the narrowest part before the splines. It's a 2.94 gear too, which might account for something, but I just thought the ring gear looked really thin for an 8.25. Guess I had the new 8.75 sitting around too long for me to look at and compare, lol.
The thickness of the ring gear is a function of the ratio, as the ratio gets numerically smaller (3.9 towards 2.9) the ring gear gets thinner to provide room for the larger diameter pinion (has more teeth). The same situation occurs with an 8.75 or even a Dana 60.
:-D I have to tell you my "back in the day" story about my first 7 1/4 blow up.If you still have you 7 1/4 in it, do a massive burnout with can count how many seconds it last doing it. Mine last 15-16 before it stopped working.
