Nokke
Active Member
Hello guys i have looked at comp cams rx296 solid roller 649/654 0,50 263/270 duration that with 11,5 in compression is that conserative
DO you have the flow sheet to the heads?What fuel are you gonna run?
thanks for all the answers. 7172 duster your engine seems strong the power looks to raise fast on the top end must be a real kick. i have ordered a comp cams rx302s-r6 with valve lift 654/655 and 269/276 0,50 duration 106 lobe center but i have 1,6 rockers so the lift is going to be 697/698 i have also sold my old headers and ordered 1 7/8 headers and i am going raise the compression to around 12.1 i hope the combination going to work
Still though by the time you set the .020 something valve lash and the loss of lift due to the pushrod angle you'll only have about .670 or so lift on the intake.
yes thats correct what do you think is the cam too small?
