1........Every single time you start it up, you have to turn the parking lights on, and every time you shut it off, you have to turn the light switch off
Cheapest and easiest, but a pain in the butt that will probably get old, after a few months
2.......Dig into the harness and identify the park circuit wire. You'll need a service manual to do that. I don't give one **** what people say, you NEED A SERVICE MANUAL. You can separate that wire, and either isolate it with diodes, or a relay, or move it back to the park terminal of the light switch, then use a relay to feed ignition power to that terminal
Most difficult, but once finished, probably the most convenient.
3.......Come up with some sort of alternative front lamps for your run function, in this day and age I'd think LED
Easier, but a little more costly.
