How to add on gauges??
Yes LISTEN !! to Adam telling you to get a different tube rather than use the cheap china made crap plastic tube they give you. Learned from experience that it's not a good Idea haha. Although I was lucky enough to not have the gauge completely installed in the car at the time it was just zip tied to the wiring harness for temporary use and the stupid plastic tube busted and oil started leaking bad at the fitting !!! Just letting you know haha
I just pitched the mechanical gauge and went with an electric. I installed mine by making a plate to accept 3 gauges, and a 1 DIN radio. My original radio space was already hacked up from the previous owner trying to install a tape deck in the dash. Some day I want to make a new plate and actually weld/blend it in to the dash for a factory look. I have VDO Oil, Volt, and Temp gauges.
