Ok so when I pulled the lower rad hose off the entire outlet pulled out.. How should I go about fixing it?
soldered with a torch, flux, and solder, just like plumbing....
I work with guy that did radiators 20 years ago. We have talked about this kind of thing. the potential for really screwing things up is very high if you don't know what you are doing. Mainly the loss of heat control and tubes becoming unsoldered.
If this happens, an amateur has dug a hole he can't get out of.
