Just started driving my car and it runs rich enough to burn your eyes, make the oil smell like gas, and make black clouds when you punch it.
It’s a 70 Duster with an 11.5:1 .030 440, edelbrock performer intake, edelbrock 1813 800cfm carb, see cam specs below, has a mechanical/vacuum advance summit brand electronic distributor, vacuum is unhooked and capped off. 800rpm idle base timing set to 17°, fuel pressure is set to 4psi, fresh 93 octane gas, cheap autolite spark plugs gapped to around .045 because why foul out expensive ones.
I want to get this car running 100% and I can’t figure out this chart I found on the edelbrock website. Can someone please explain to me how to decipher this or give me a recommendation on what I should do?
Chart part1
Chart part2
Cam specs
Spark plug after in town driving
I think that’s everything.
Chart part1
Chart part2
Cam specs
