How To Recondition a Sure Grip Cone
  1. Seansmopar
    Seansmopar Well-Known Member
    122
    25
    Nov 27, 2012
    Hebron, Indiana
    Local Time:
    6:45 AM
    I Purchased an A bodied 8 3/4 741 differential that looks like it was separated from the car and sat in a backyard for years. Taking it apart carefully trying to preserve all bolts and nuts I noticed the pinion matched the pinion of 742 case and then looked at the numbers on the ring gear and shows 2800270 with research says it belongs to a 742 case. I'm learning as I go about this unit and visually can tell upon disassembly this is a cone style. I noticed the inside cone gear appears to be beat up on the side that sits in the cone. Question does the gear and the inside of the cone have to be machined as well. I try to rebuild by myself as much as I can...Thanks..Sean
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    71,464
    46588
    Jun 7, 2010
    Georgia
    Local Time:
    7:45 AM
    A picture would be helpful here.
  3. Seansmopar
    122
    25
    Nov 27, 2012
    Hebron, Indiana
    Local Time:
    6:45 AM
    Ok I will take some photos tomorrow and post..thanks for replying!
    Sean
  4. 340dartley
    340dartley Well-Known Member
    519
    127
    Feb 4, 2007
    Local Time:
    4:45 AM
    I have done this exact repair about 20 years ago. I was able to chuck the cones up in my break lathe and shave about. 060 off of them. I reinstalled them and they worked great. I was told this trick by my friends dad who was an old Chrysler line mechanic from the 70s and who also campaigned and worked on several mopar bracket cars. Great thread.
  5. Seansmopar
    122
    25
    Nov 27, 2012
    Hebron, Indiana
    Local Time:
    6:45 AM
    Here is the inside of the cones..I will bet the previous owner got them hot.
    [​IMG]
  6. Seansmopar
    122
    25
    Nov 27, 2012
    Hebron, Indiana
    Local Time:
    6:45 AM
  7. Seansmopar
    122
    25
    Nov 27, 2012
    Hebron, Indiana
    Local Time:
    6:45 AM
  8. Seansmopar
    122
    25
    Nov 27, 2012
    Hebron, Indiana
    Local Time:
    6:45 AM
    741 case with a 742 pinion...I hope I can salvage something with this case..it all turned before I took it apart..and it was no bind or slop..
    Sean
    [​IMG]
  9. dwhip361
    dwhip361 Well-Known Member
    141
    66
    Jan 30, 2014
    West Palm Beach
    Local Time:
    7:45 AM
    Subscribed, great info, thanks guys!
  10. RustyRatRod
    71,464
    46588
    Jun 7, 2010
    Georgia
    Local Time:
    7:45 AM
    I wouldn't worry with any of that. You MIGHT go over them with some wet or dry and some mineral spirits but it's not necessary at all.
  11. Seansmopar
    122
    25
    Nov 27, 2012
    Hebron, Indiana
    Local Time:
    6:45 AM
    Do you think it all still needs to be shimmed any where?
  12. fishy68
    fishy68 Tyr Fryr's Inc. FABO Gold Member
    16,956
    951
    Jan 11, 2005
    Central, IL (Hooterville)
    Local Time:
    6:45 AM
    That doesn't look like a 742 pinion to me. Looks like a typical 741 pinion with the spacer installed
  13. RustyRatRod
    71,464
    46588
    Jun 7, 2010
    Georgia
    Local Time:
    7:45 AM
    I don't know. I would have to see it in person.
  14. Seansmopar
    122
    25
    Nov 27, 2012
    Hebron, Indiana
    Local Time:
    6:45 AM
    You have to look closely at the spline.i have found a photo for comparison. And the ring gear shows 2800270 3:23 for 742
    [​IMG]
  15. carls72dart
    carls72dart FABO Gold Member FABO Gold Member
    368
    200
    Dec 31, 2008
    massachusetts
    Local Time:
    7:45 AM
    Thank you for an education! I've always wanted to rebuild a center section, now I feel more confident doing so! Thanks Rusty:)
  16. badlilred79
    badlilred79 badred360 FABO Gold Member
    4,204
    539
    Nov 3, 2004
    Crossville TN
    Local Time:
    6:45 AM
    nice work#-o
  17. Oldmanmopar
    Oldmanmopar Going left turning right FABO Gold Member
    9,047
    5531
    Jan 8, 2009
    Danielsville Pa. 18038
    Local Time:
    7:45 AM
    This took some time to take all these pictures and share this info. And for no other reason than to help fabo members. Thanks Rusty very good information for all. Steve
    • Like Like x 1
    • mguner
      mguner How many is too many?
      5,129
      364
      Nov 26, 2006
      Amarillo,TX
      Local Time:
      6:45 AM
      Thanks Rob! You just gave me a great idea with what to do with the old axle stubs from the Dana I converted. Alignment tools! Also maybe make it a fixture for the lathe to hold the cones for turning them off. Might keep one for the D-200....
    • Cranky
      Cranky Banned and proud
      210
      92
      Nov 25, 2009
      Pasadena, TX
      Local Time:
      6:45 AM
      It's not a great pic, but I made these T-bars a lot of years ago. Also use them whenever I find a Sure Grip at a swap meet to check a SG for resistance.
      [​IMG]
      [​IMG]
      [​IMG]
      [​IMG]
    • 19DART66
      19DART66 Well-Known Member
      297
      132
      Nov 19, 2008
      Ballston Lake NY
      Local Time:
      6:45 AM
      The only thing different we use to do was to add 727 clutch springs inside the four pre load springs, a little tough on the street on corners but it kepted both wheels locked together at the drag strip.
    • mean318
      mean318 Well-Known Member
      204
      8
      Jul 19, 2006
      Schweinfurt, Germany
      Local Time:
      1:45 PM
      Where does one find spider gears for these units? I have one that needs a set and another that needsgears and shaft. Thanks for the writeup!
    • john-9
      john-9 Well-Known Member
      157
      70
      May 11, 2015
      Oldcastle , Ontario
      Local Time:
      6:45 AM
      you can use the cross pin out of an 8-34 open differential -- the spider gears are not available anywhere -- you have to salvage them , if possible , out of another trashed sure grip
    • mean318
      204
      8
      Jul 19, 2006
      Local Time:
      1:45 PM
      I was afraid of that. Thanks!
    • Fisho
      Fisho Well-Known Member
      244
      119
      May 11, 2017
      Barrie, Ontario
      Local Time:
      7:45 AM
      @RustyRatRod I took my cone type sure grip apart today. 2 of the springs are broken, do you happen to know where I could find replacement ones? Thanks!
    • RustyRatRod
      71,464
      46588
      Jun 7, 2010
      Georgia
      Local Time:
      7:45 AM
      I have a few. It is an 8 3/4?
