Snake
Mopar Nut
The whole car is covered in overspray.What can I use to remove it this is awfull.Is there a safe compound for clear coat or wax and polish it.
You can try a clay bar, if that doesn't work then it's time to color sand and polish.
Get 2000-3000 grip sandpaper, keep the paper and the surface wet, sand until the clear coat has a haze, then apply buffing compound and buff with a buffing wheel until the haze is gone. AKA color sanding.:cheers:
