Instructions are in the repair manuals you can get from a few sources, I forget where I got mine, but really I did not need it to replace my glass.
I had all the pieces in a big pile from when I removed them years prior before paint.
I just took my time and figured it out, and believe me, it was not fun because I had a roll cage which made it much worse to work the glass in.
If you already have everything installed, just take a mental picture of it and take your time and use the other side as a reference.
Really it's just all nuts and bolts and those stupid slide/roller thingy's, but if you already have the glass in and are just replacing it, half the work is done for you already, just take it all out and try to remember how you did it and do the exact same thing in reverse and make sure nobody is within thirty feet while you throw wrenches in frustration.
Probably the most complicated window regulator set up I've ever dealt with.
Not much help huh?
