[SOLD] Howard hydraulic cam small block
Tawny Demon
maine
a 3500 stall and 3.91s but I like tall gears I currently run 4.88s but they recommend 3.55 and up
I have a 2800 converter, holley 750dp, 3.91 gears and headers. Just a street car. Would this cam work for my set up?
that would work great and with a stand out idle with great torque and throttle response
According to Howard Cams, the duration you referred to above is the advertised duration, the duration @.050 is 230/236
Here is some info that may help you sell the cam:
277 283 advertised duration, 230 236 duration at .050, .531 .547 lift with 1.5 rockers, 108 lobe separation ange, 104 intake centerline, Hydraulic
2600-6200 Lopey idle, Strong mid range. Good throttle response. 2400+ stall.
Good luck!
Sounds like an excellent street cam.
