Hows my 360 run?
Ori
Fort Collins, Colorado
Hey guys! Got back from the track and was wondering what your opinions are on my magnum 360 and quarter mile times. Here's the build-
Magnum 360 with forged pistons and 9.5 comp.
Rhs heads(stainless 2.02/1.6)
Custom forced induction cam, 236/234, .525 lift
Off brand airgap intake with a 600cfm eddy, firecore wires
904 low gear with 3500 stall and 3.91 gears, 275/50/15 mt et street tires for the back.
Car with me weights 3505lb.
Now for the times- everytime I ran(3 times), I got a 14.00@95mph, 1.93 60ft time. ALSO keep in mind I was at a track of 5500ft and it was 90degrees. I checked the D/A and it was 9200...eek!
Now time for some feedback :D
14 flat with a DA of 9200.....now bad....anything to improve the 60 ft help the overall ET...
if you could borrow a good 750 Holley dp....you will probably seen an improvement
I'd say that's pretty damn good. I agree 70arrcuda about the 750 dp. That 600 is a little small for a 360. Probably notice a big difference at the top end.
Not bad.......I believe at sea level that should convert to 12/teens @ 110 - 112 mph......a 750dp properly tuned should drop you into the 11's easy :glasses7:
Rickster
Not bad, but it needs more carburetor.
