shobes
We were talking today at the shop trying to figure out where the HP will be when done with the latest changes to my engine.
1973 340 .060 over KB pistons 10.5-1 compression,stock heads 1.88 cleaned up and bowl blended,Comp XE274 cam, Air gap RPM intake,Holley 750 DP carb, MSD 6al, headers.
I'm thinking in the 380-390 HP range but let me know what you think.
****edit My bad on the piston number, I have the build sheet(Kilpatrick's) from the prior owner and for some reason thought they were 107's, but in reality all the info I have is that it's a KB piston set.
