moparmatt19
Kinda a general question on the HP and TQ gain from 10.1 comp to 11.1 comp. How much will it really gain? Based on Iron headed sb.
Agree also... Reason saying or asking is bc if there is not much more difference then why run 11.1-12.1 and need race fuel instead of running 10.1 and cheaper gas? Or is there really a noticeable difference? Let's say for a base to answer the question, using a camshaft like 255-265 dur @ .050 with LSA from 106-108.. Both can be run on pump or race fuel depending on setup. But why make it have to run on race fuel if your really not getting that much gain??? See where im getting at? Just seeing the Truth about all this hype on compression
When I went from 10.2 to 11.2 it was noticeable. Idled better, quicker starts and better cold idle, torque, very slight increase in MPG, sounded a lot better.. Way nicer POP out the tips.
I don't see why people push the limits on a street engine especially if your a novice. It's not really worth pushing over 9:1unless your cam choice requires more. But for a race engine winning cost money, once you go passed your basic high rise, cam and headers performance becomes more and more expensive with less and less gains. If your running 15-20 hp less than everyone else your not gonna do so well.
Rusty, I'very stated before most of my knowledge is more from reading (a lot of reading) than real life experience
Cars I've done before mainly been a few bolt on like high rise cam, headers, and from my cousin late model and uncle top alcohol and a lot of hot engines my other uncle has built for various people around town.
If my info is misguided advice how so??
I see a lot of people on this forum that build High compression engine to only later try to figure how to get them to run on pump gas that's why I said the 9:1 comment. And the race comment is of course depending on the situation but if you have to detune your engine compared to the other guys to run pump gas more than likely your probably not gonna be as competitive.
I guess I was a little confused by your post I get you now
No problem! I confuse myself all the time.
People see all these fancy magazine articles and stories on forums about high compression and pump gas and don't realize it takes lots of experience and money to do it right.
Plus, even when done "right" there's still a very real possibility that it will not like pump gas on certain occasions. Hot outside temps coupled with high humidity sittin in traffic a long time. Or in a truck pulling loads.
People do things without using their own head. If you look back at history, anything over 9:1 compression required premium fuel. And I mean back in the 60s to the early 70s.
One example comes to mind, because a neighbor had it where I grew up as a kid. It was a 1971 LT1 Camaro. 9.2:1. It was totally all original. Had "PREMIUM FUEL ONLY" right on the sun visor and on the gas filler door. Premium fuel. In 1971. That was at or over 100 octane and LEADED.
Would it run on 87? Sure. Until it got good and HOT on a hot day and then it would knock and ping like all hell. Without expensive building techniques like quench or aluminum heads, around 9:1 is indeed the limit on pump gas. Course you can cheat some by running a "big" cam, but then, what's the point? You just lost cylinder pressure. It will be more efficient with 8.5:1 and a matching cam to give optimum cylinder pressure. We are after all talking about a street engine.
No matter how much you talk to some people, they will just not believe an engine can be powerful under 10:1 compression and it just ain't true.
Yup and I know people will argue "as long as you keep DNC under blah blah blah..." but again, that requires a learning curve most beginners don't have. Besides all that, it's just a safe bet to build a lower compression engine anyway. Especially with this crap ethanol in the gas.
With nothing else changing you might not see much. Both of my 440's were a static 10.5:1. Both ran/run on 92+ pump swill.
IF you up compression the cam needs to be adjusted to that new compression as well as other items if needed. Look at the compression ratios in modern performance engines. They aren't low.
N/A
2015 Camaro 11:1
Challenger 10.9:1
S2000 11.1:1
GT350 10.3:1
Boosted
Hellcat 9.5:1
GT500 9:1
