Hugh is from Canada and has a 1967 Barracuda
67 Barracuda Hugh
New Member
Thunder Bay, Ontario, Canada
hi guys. I have a 1967 Barracuda with a 383. Factory was a 273?. It is has been a frankenstein car. 70 cuda front suspension,
QA1 K member, Borgeson Power steering, 727 automatic/rebuilt/shift kit/2500 stall/flywheel, Sure grip rear end 489 housing with 8 3/4 323 gears
New axles and 10 inch drum brakes in the rear. Disk upfront. I have purchased a rear disc brake kit for a winter project
I am grateful to have been accepted. I have already scrolled around the site as I have a ton of electrical gremlins and the site has been very helpful.
I want to change the carpet in the rear area and put down sound proofing. I am having a hard time removing the back seat. I successfully removed the rear seat cushion. I successfully removed the divider between the trunk and passenger compartment. I cant seem to figure out the rear Seat Back. This is the hinged seat back that is unlocked with the barracuda handle. There are two 1/4 caps crews each side but nothing seems to free up the seat back. Looking for help
Welcome from New Jersey!
