wicked70496dart
Active Member
Just finished freshening up my 496 and notice I now have a lot of rocker noise/chatter. Had the same noise before but with a lot less chatter. Had a valve job and new springs but all the same valve train. My only issue was the heads were resurfaced ( just cleaned up) which made my push rods tips at the rocker about .025 to .030 gap from contacting the rocker. Is this o.k.? Any other ideas why they are louder now? Rechecked the valve lash hot .018/.020 2 times using EOIC method. Noise is coming from both Banks. Oil pressure hot 70 pounds in park and 50 pounds in gear. Have no ticking at all just this chatter type noise. Thanks Matt
