340 mopar
Active Member
Does any one know if hughes has caught up with their back orders? How long of wait, if any? Are they doing the tooling or did they hire another shop?
Thanks
Thanks
Thanks
had mine b out three or so and no complaints once set up they are great worth the wait, i love them
I am still wondering about no needle bearings on shaft has any one out there rather gone with more expensive t&d's
Not to mention the extra weight fighting your valve springs. I run whatever is lightest and gets the job done. I run stockers with my 284xe hydro lol!As far as I'm concerned needle bearings in rocker arms are a PITA. Out of all those needles it's only the bottom 3 or 4 that are doing anything, the rest are there to keep the bottom ones in place. Those needles will wear the bottom of most shafts I've seen over the years which causes your push rod clearances to open up especially if this is on a street car. The worse thing though is one of those bearings decides to come apart, and they do sometimes, now you got needle bearings all over the inside of the engine. Whereas the aluminum or cast iron (mopar) rockers work just fine.
