OK, it's Thursday and most everything is back to normal in my City. Can't say as much for Rockport or Houston and all the towns that were in the direct path of Harvey!! My cable and internet are up and running so I can finally post the pics I took of my Emergency Hurricane Survival Kit:
Had to pack everything into the garage (including the Cuda and my son's car), Hagerty will only cover car damage to the Cuda if it's garage kept.
Had to leave my daughter's car in the carport that I built: It was covered with stuff from the wind blowing so much:
My carport (automatic) door faces the street and I wasn't sure if it would be able to withstand the high winds so I raised it up about 3 feet and built a heavy wire screen wall so that the wind couldn't get trapped and bend/rip the automatic door. I also attached a 2X4 brace to the door to give it some strength.
Here's one of the telephone poles that support the carport roof, I dug down 6 feet to sink the poles deep!! They weighed about 800 lbs each and it took 6 guys to raise them high enough to drop into the holes. My plan (10 years ago) was to make the carport hurricane proof....so far so good!! You can also see the wooden I beams above with metal tie straps:
I put these fence braces in for the hurricane in hopes that it would save my fence (I have 3 dogs)...the storm was already blowing as you can tell by the mess in the yard:
Here a good pic of the overhead I beams:
I built some double staggered 2 X 12 beams with 1/4" steel plates to span the space between the poles:
Despite all the winds and high gusts the carport never budged at all. I expected it to sway a little but it never did?? I already have plans in place to reinforce the fence better. I originally used 4 X 6 treated fence posts and sunk them 4 feet into the short concrete wall but the 4 X 6 posts would be no match for 120/140 MPH winds. There are a couple more storms in the Gulf (right now) and out at sea headed this way so I'm limited on time to get to work preparing for the next onslaught!!
treblig
