Sounds to me like you already have a good idea = just want to go racing.
My first car (bought in 75 for $400) was a Blue w/white stripe, 64 GT, 273, 2 brl, 4spd, single exh, buckets & consul. I have a fond place in my heart for the early A's.
Keep going Hector, can't wait to see the video. You w/big smile, then the sound of the revving engine followed by a slight squeak of tires loosing traction a bit :burnout:, some smoke then another squeak as the tires grab and then the grand finally, as the disappearing tail-lights are complemented by the exhaust note of the 440 . . .
You go young gun!!! Subscribed
If you are going to just fill it again, use filler with fiberglass strands in it. It should hold up much better.
Nice Build you have going here. Keep it up.
thanks, i plan on it!i like the radiaused wheels wells with a little flare like that. looks good with the right wheel combo. i would definitel yuse a fiberglass reinforced filler, get it as close as possible with a grinder and a real rough sanding disc, then finish it off with regular body filler.
i think i got out most of the bondo from this canyon, i think i am going to put bondo back in there but add a bunch more of tack welds or brazing rod so its not a half inch thick. there was way more on there then needed to make it look ok. its not going to look perfect when done but like the guys that did it before, i just wanna go racing. plus i think things look cool when they arent perfect but whatever. heres some pics. also how can i decode this vin?
thanks
hec.
found another early dart with the same wheel wells...
i dont even know where to begin.
Here goes nothing...
Hi I'm Hector! i look like this (kid in middle), I suppose I'm a "young gun" at 15.
