jahsh
Anybody have experience putting in a hydraulic clutch into a early A-body? Looking for options and what people have done.
Any help would be great!
66dartgt said:I considered doing this on my 73, but never did it. Keisler makes hydraulic master cylinder conversions for mopars, (you might know them as the tremec 5 spd conversion people ?). I seem to remember it fitting into the oval opening for the clutch rod that normally passes thru the firewall. I think it uses the stock pedal and somehow adapts it to the cylinder. From the clutch master cylinder you would use a hydraulic combination throw out bearing which incorporates the throw out bearing and the slave cylinder. Mc Leod makes these. I'd call or check the web sites at Keisler or McLeod for more info. Hope this helps -
racingsnake440 said:I used a mid 80's Nissan pickup master and slave setup. It fit pretty easily with just a simple bracket on the bellhousing and a small hole in the firewall. Total cost was about $50.
racingsnake440 said:So if the Doug's headers won't fit with a 10.5 clutch, is there a problem using them with a Lakewood bellhousing?
jahsh said:The problem is with the clutch fork that needs to be used with the my 10.5 inch bellhousing. From what I can tell, this same problem might happen with TTI's as well. On the standard early A-bbody 10" (vs. 10.5") bellhousing and clutch the fork is much smaller and it tighter into the motor. The fork I have to use with the 10.5" clutch is longer and hits the headers.
daves66valiant said:Was this the car?
I'm running the TTI's, the Lakewood and the Keisler and I don't know what's going to happen yet but I will keep you informed. Hope the pic helps. Can't remember his name. Saw him at the Fall Fling recently.
lilcuda said:Got any pics? There are different forks that will work with the 10.5" bellhousing. I have a shorter one in my 66. I'm also planning on Doug's Headers eventually, so I would like to know what I'm up against.
Another thing that will give you problems is the fact that one of the header tubes will be too close to the Keisler master cylinder. I saw 65 Cuda at Spring Fling that has a Keisler hydraulic setup with Doug's headers. He had to move the master cylinder over to the left about a half inch or so. I'm planning on using a master cylider that mounts up higher so I don't have that problem.
Good luck!
Lee
1966 Barracuda, 340 4 speed
jahsh said:I'll work on getting some pictures of the fork.
Is the master cylinder you are talking about that is mounted up higher the Wilwood?
