Several of the posts I have read have led me to believe that in converting to a hydraulic clutch linkage, I will not want to use the over center spring on the pedal assembly. Is this correct? What returns the pedal to a full-disengaged position to keep the throwout bearing from riding on the pressure plate?
I am currently working on the (stock) pedal assembly, and would like to have this issue settled so that I can have plating/powdercoating completed. I have purchased a Wilwood master cylinder and a rod end to connect to the pedal and the firewall will be modified to get the angle correct for mounting of the master cylinder. I will be switching to a Tremec 5 speed transmission and using a hydraulic throwout bearing.
