Hydraulic Clutch Master Cyl diameter
gzig5
Mequon, WI
Looking for feedback from those running Hyd clutches on what the piston diameter and stroke are on the master and what you are using for a slave cyl? Hyd throw-out or push/pull cylinder with the normal throw-out fork. Looking at doing a home-brew due to the cost of the commercial kits.
There was a conversion on the Old Bigblockdart tech pages but it's been missing since they changed their site. Someone posted a link to the old pages but I lost it. Does anyone have that link ?
I called Wilwood and they told me what bore to use with a McLeod hydraulic throw out bearing.
I've got a friend who used a stock fork and speced out a slave cylinder which he made brackets for on his bell. A little too busy for me. My set up works great. The bearing was the expensive part like 450 but the master was only like 80 and I have a 3 finger PP. A diaphragm PP would be very soft like a new car.
